GE Swivel Top Canister. When Was It Made?
michaelt
Phoenix AZ
Hello. I just purchased a nice GE Swivel Top cleaner from ebay. It's a small one, unlike the C7s but not a Lowboy model. It's beige on top and dark brown on the bottom and has an older style swivel top. The model # is V12C8. Does anyone have an idea when it was made? It has the deluxe bumper with the General Electric name spelled out on it, but the exhaust blows from an opening on the bottom. It appears to have 2 metal brackets on the back, presumably for attachment or cord storage.
Thanks,
Michael
Hi Canisterman. Thank you for your reply. I didn't know they made Lowboy models that early. I thought they were made later. Would this one be a single-fan model?
Michael
THe first swivel top GE canister was the model 815
I have a model C4 GE Roll Around cleaner that of course has a swivel top. It is beige & sort of a paprika red. Has the double action rug unit.
From Doug Smith’s website, it looks like the GE Swivel Top 815 debuted in 1952. Was the Air Way tower canister with the swivelling topside hose connection created earlier than 1952? Who was “first on the block” with a top side swivel hose?
Thanks,
Michael
Hi, I just purchased this same vacuum and am needing to find a replacement hose, do you have any suggestions?
I was searching there, but couldn’t find any. Maybe I need to wait it out :) Got it for $30 on FB marketplace, such a freakin steal!
Patience and persistence are key attributes when collecting. I sometimes stalk ebay for many years waiting for a component I need to finally show up. Then I swoop. Just this past week a vacuum arrived on my door that I have been looking for for the better part of a decade. I often will buy just a hose or power nozzle for a vacuum I want in my collection knowing that in the fullness of time the rest of the vacuum will show up. I also know that if I don't buy the part when it is available, the vacuum will show up on ebay without the part I should have bought years before when I had the chance. I am currently on a hunt for the power nozzle for the beautiful electric blue Panasonic MC-CG887. I have the rest of the vacuum in great condition but no power nozzle. One will show up eventually. I had the same situation with another modern Panasonic vacuum and in time three of the correct power nozzle showed up. There is a steady drum beat of GE parts on ebay. You might also search under the Premier brand as those are just GEs with a different name.
If anyone wants the first lowboy as described above I found one hiding in a corner of an estate sale garage. It's good and complete but with a brown Kirby hose on original GE ends.Needs a new home.Maybe yours?--Jimmy--423-268-4841.
Thanks,
Michael
Hi Mike,
I did some "data and photo digging" and assembled the following models list, photos and ads for you and others as there is such limited Swivel-Top information shared online. Btw, G-E's markets in other countries had their own model IDs and stylings.
US G-E Swivel-Tops/Roll-Arounds -- Standard & Deluxe designs have 5-quart disposable bags; 2 18-inch steel wands; 18-foot cord; blower port on side, cloth filter bag
Miscellaneous Info.
*Actual Color Name listed in ad (note: ‘Woodtone Brown’-listed in the color list attachment and ‘Cocoa’ may refer to the same color)
**Known US or CA G-E or Premier period appliance color - not ID’d in ad
The first alphanumeric in the model IDs (e.g. V11, P1) seems to be a catalog or lot number as it differed with the second alphanumeric (C__)—the only designation typically used in consumer ephemera and advertising. There are likely more such designations than those listed below. G-E was known to update its model IDs—some of which are shown in the attached photo’s, so it’s also possible that the first characters represented variations.
Introductory Years of Located Models (stamped on bottom of canisters or later on stickers) by - available ad & photo features (incomplete)
Design 1 Models - higher/narrower silhouette; toggle on/off switch; fabric weave on 18-foot rubber hose (1951-55); ribbed vinyl hose (1955-58); added features during production are noted below
Available accessories: Hose, de-mothing bag, dusting brush, upholstery nozzle, crevice tool, extension tubes, flip-over rug and floor nozzle
AVC-815 1951, 2-tone **Pearl Gray, 600W
C-1 (V-13) 1953, 2-tone **Cadet Blue, 600W
C-2 (V-13) 1954, style 1 - 2-tone **Turquoise Green, 600W; C-2 (V-11) style 2 - 2-tone**Petal Pink; new flip-over floor/rug tool; new roll-around dolly (1955)
C-3 (V-13) 1955, new roll-around dolly; new ribbed vinyl hose; flip-over tool; style 1 - *Coral/*Pink, 720W; style 2? - *Pink, *Beige & *Cocoa
C-4 1957 **Desert Beige/**Cocoa Brown (going by similar-looking Canadian G-E model VC2B ad), roll-around dolly
C-5 “Pacer” 1958, roll-around dolly
Design 2 Standard & Deluxe Models (1958-72) - lower/wider silhouette, slide on/off switch, built-in casters, 65-inch hose—vinyl (1958-59) woven wire-core hose (1959-72)
Available accessories: double-action cleaning unit (introduced for deluxe models in 1957) or updated twin clean floor nozzle unless basic rug-floor nozzle is listed below; dusting brush, fabric nozzle, crevice tool, floor/wall brush (deluxe models), cloth filter bag
C-7 (V13, V15) 1958, **Cypress Green/Chrome, automatic cord reel, piggy back tool caddy, dual exhaust, larger casters
C-8 (V12) 1960, **Woodtone Brown/**Espresso Brown
C-9 (V12, V15) 1960, 2-tone **Cadet Blue/White bumper, 750W
C-10 (V13) 1962, *Cypress Green/*White, 750W
C-11 (V11) 1962, Deluxe - *Espresso Brown/Chrome/*White, cord reel; piggy back tool caddy, unverified: dual exhaust & larger casters
C-12 (V12) 1962, *Beige/*White, toe-touch power switch, 750W
C-13 (V11) 1966 *Beige/*White, cord reel, detachable tool caddy, dual exhaust, larger casters, 830W
C-14 (P2, P-5) 1969, **Celery/**Moss Green, basic rug-floor nozzle, 830W
C-15 (P1) 1971, **Celery/**Moss Green trim, cord reel, tool caddy (continued as Premier)
C-16 1971 (P1), **Celery/**Moss Green (continued as Premier)
C-17 1971, Deluxe - cord reel, detachable tool caddy, hose suction regulator (no online photo located)
C-18 (P1) Super Deluxe, 1971 - **Celery/**Moss Green/Chrome, cord reel, detachable tool caddy, 2-speed power selector, 3-button suction control, bag indicator; unverified dual exhaust & larger wheels
SC-1 Floor Washer-Dryer blower accessory, 1960
Design 2 G-E / Premier Label Models c.1961-c.1965 (no online photos located)
PRC-1
PRC-2
PRC-3
Lowboy design features - low/wider silhouette, single-fan motor, blower port on bottom, 750W (all?), 65-inch hose, 17- or 18-foot cord; dusting brush, crevice tool, fabric nozzle, basic rug-floor nozzle (c.1963), cloth filter bag
C-6 (V11) 1958, *2 Tone Pearl Gray/*Coral
C-61 1959, Design 1 & 2? (Both shown in different ads), Two-Tone Color Styling, 750W
C-65 1963, Design 2
C-85 1965, Design 2?, cord reel
C-166 1963, Design 2, Red/White
C-177 1965, Design 2
C-188 (V11) 1966, Design 2, Turquoise Blue
C-200 1967, Design 2, *Avocado/*White, toe-touch switch
C-350 (P1), 1969, Design 2, *Harvest/*White (continued as Premier)
Design 2 Canister-Upright w/Power Nozzle
C-100 1963 **Cocoa Brown (same as or similar to C-4)/Chrome
US Premier Canisters (1972-c.1980--production shift to G-E's subsidiary)
Thank you, Keith, for posting the Premier brochure.
https://vacuumland.org/threads/the-ge-and-premier-electric-vacuum-cleaner-line-up-😊.40081/
C-20, 1973, Shagmaster tool, airflow regulator
C-29, 1975, Deluxe, detachable tool tray
C-450 Whirlwind, 1977, **Harvest/**White bumper
1503 - Chrome/**Moss Green/White
1553 - White/Chrome/Black?, TURBO-Head, detachable tool caddy; (C-17 design)
1754 - White/Chrome/Royal Blue, TURBO-Head, detachable tool caddy; (C-18 design)
3501 - White/Red or Orange
3508 - White/**Harvest
3511 - White/Chrome/**Harvest
3553 - White/Red or Orange, TURBO-Head, detachable tool caddy
3595 - White/Harvest, TURBO-Head, detachable tool caddy
  • US G-E Swivel-Top:Roll-Around Photos 1951-58 intro's.png
    435 KB
    342.4 KB
    428.4 KB
    272 KB
I
    187.1 KB
    138.8 KB
  • 1955 Feb 26 BEAVER VALLEY TIMES - G-E Swivel-Top C-2 No More Tug & Lug ad.png
    169 KB
    176.5 KB
  • 1957 Nov 2 GETTYSBURG TIMES G-E New Waxer-Polisher & Deluxe Swivel-Top presumed C-4.png
    218.4 KB
    174.6 KB
C-6—C-13 ads
    179.2 KB
    156.5 KB
    171.1 KB
    155.7 KB
  • 1961 Feb 9 TOLEDO BLADE - G-E Swivel-Top C-9 & Floor Washer-Dryer SC-1 - special offer.png
    457.3 KB
    240.6 KB
    76.9 KB
    264.5 KB
    448 KB
    208 KB
C-14—C-18 ads
Additions to Model List
C-13 Super Deluxe
C-17 2-Speed, full-bag indicator light
    223.4 KB
    291.7 KB
    93.7 KB
    119.8 KB
    273.4 KB
C-61, C-65, C-166, C-177, C-188, C-200, C-350
    135.9 KB
    222.2 KB
    251.9 KB
    129.6 KB
    227.1 KB
    148.3 KB
  • 1969 Jun 25 PRESS-COURIER - G-E Swivel-Top C350 in the color of the year - harvest!.png
    215.3 KB
I wonder if this was the disposeable vacuum of its time? For how many ads were run for it for all these years, you dont seem to see them that often.
It has seemed to me that their build quality and G-E motors were on par with their contemporaries until the later Premier years as some have indicated; they just were so basic and less robust in comparison that they were less popular. I used to own a standard model C12; and the only major flaw I found was that it was prone to tipping. That is probably not the case with the deluxe and super deluxe models that are heavier with cord reels and power and suction controls. I would be interested in knowing if all or some of the G-E and Premier versions had 2-stage motors; and if the casters were all the same size among trim levels.
By the way, there was at least one Design 2 Lowboy model sans casters according to the ads (no model ID was given). Note: Like Eureka, G-E tended to phase out its model names. Only a few ads in earlier years used the term 'Lowboy'; which, incidentally, was used for other appliances in those years.
Also, the fact that repair parts have been harder to obtain for the last 35-40 years likely sent more of them to garbage cans or scrap yards rather than garage sales, thrift stores, or the online market. According to fan-of-fans, Black & Decker continued to make the parts for a time when it acquired Premier Electric (see link to archived thread). I read another archived thread in which someone stated the transaction happened in 1978 followed by its acquisition of G-E's small appliance division in 1984.
https://vacuumland.org/threads/ge-premier-post-1982.42506/#post-446759
I located some more G-E models in ads: C-62, C-63, C-64, and C-130S; so there may be still others.
    256.7 KB
    211 KB
  • 1962 May 9 SPOKESMAN-REVIEW - G-E Floor Polisher FP-7 & Swivel-Top C-64.png
    380.4 KB
    206.8 KB
