New Kenmore Upright Vacuum
Chetlaham
United States
I just want to thank everyone for the innumerable time and priceless advise given to me in the other thread.
So here is, my new vacuum cleaner. In so far I really like it and it works as advertised. I vacuumed the downstairs and upstairs carpets and it really does an excellent job. 99% of the time is sucks everything up on the first pass. Suction is almost if not just as strong as my old Kenmore Intuition. It scrubs the carpet and leaves great looking lines. It is quieter, glides easily and a bit less heavy. The LED lights work well, the dirt indicator light is not a gimmick in that it actually lights up when going over a dirty spot and shuts off when going over a clean spot. One thing I noticed is that not a single bit of sand, crumbs or grit was flicked out from underneath which I really, really appreciate unlike some other vacuums I had in the past.
Only thing I dislike is that the hand attachment hose is shorter, but other than that you get your moneys worth. And best of all it is based on an older Panasonic design which I love. It takes Type O bags which I think are among the best.
I am open to any thoughts, comments, likes dislikes ect.
    1.5 MB
    161.1 KB
    179 KB
    1.7 MB
Not sure about the motors in these but the original Panasonic built versions came with their 3D Inducer Motor, which had 20% more power than the motor that came in the original Intuition series ( upright and canister Intuitions used the same motor ). Likewise Elite canisters use the same motor these use.
Very nice machine! Good luck with it though, online reviews indicate this particular model has a problem with one of the 2 brushroll motors failing and causing issues. These are good uprights, but I would strongly suggest getting your old Intuition fixed and keep it as a backup machine.
BTW, the Kenmore 31140 was pretty much the same vacuum, minus the dirt sensor, headlight mounted on body, and the conventional motor/ v belt/brushroll setup. If you old Intuition is unrepairable, maybe find one of the 31140 models and set it aside.
I wish the 31200 was still being made for a bit longer if not today. Not only I thought it looked cooler but also I liked the design better. The hose was longer and I like having the wheels on the base instead of the nozzle. I actually saw one of those at the thrift store not too long ago that I wanted to get but I sadly had to pass on it because the brushroll wasn't working even after pushing the reset button. This is one of the reasons why I prefer having belts on vacuums, however I do love the direct drive design on my Kenmore 90 Series top loader and LG front loader washing machines. But if I had to have a direct drive vacuum and if the one of my choosing was still being made today, I'd pick the Panasonic MC-V7307D. Or if it had to be a Kenmore, I'd pick the purple Progressive.
I found a new soleplate for his Intuition on eBay for $16 so he ought to be good to go.
Is the 31140 still being manufactured? I can't find an Amazon listing.
