Watts vs. Amps
shrink1982
Active member
Indianapolis
Why do American vacuums list amps while European vacuums list watts. For example, my SEBO D4 Premium, I believe, is 1300 watts, however, my new Maytag is 12.5 watts. What is the difference?
I looked on the ration plate of my Kirby Diamond Edition and it doesn't list watts or amps.
The amp listing on an appliance is usually the maximum amps it draws in good condition. There's a simple formula to convert watts to amps, but when you're dealing with electric motors, they have variable amp draws like when starting up and when loaded (working).....so the formula gets more complicated.
I like to see amp ratings on an appliance so I can figure out if a house circuit can take however many combos of appliances at the same time. When I was plumbing, I would generally refuse to put a water heater on its own 20amp circuit. Sometimes it would work, sometimes not....they need a 30amp circuit by design/code.
Kevin
David,
Your Kirby Diamond has a rating plate and it will say:
120V~ 50-60 Hz 7A
And I hope your new expensive Maytag DOESN'T say "12.5 watts" as stated in your above post.
To answer your question, as best as I can figure, Americans have been at 120 Volt system for so long, why bother to give a Watt rating? Just give the Amperage as it is an easier to understand single, non-calculated number.
The rest of the world can handle Wattage, which is calculated by:
Volts X Amps = Watts
I'm betting that it's easier to give a total power figure because more than one voltage standard exists. Some countries have 100, 110, 120, 220, 230, 240 voltage standards. Here's a complete list to boggle the mind...
Bill
http://www.worldstandards.eu/electricity/plug-voltage-by-country/
It may be that Europe is the birthplace of the canister / cylinder vacuum and they have been much more focused on improving the features related to suction and airflow compared to North America. One of the main differences in canister design between the two sides of the ocean is the variable speed motor. It has always been far more common in Europe to see canister vacuums offering variable speed motors which use an onboard voltage transformer to adjust from the maximum 240 volts down to more gentle settings. You will often see the adjuster labelled by wattage for the settings on these European canisters: 1400 watts, 1000 watts, 600 watts, etc.
In comparison, North American canisters have rarely offered "Electronic Speed Control" - and often only on the deluxe top-of-the-line models. Our canisters more often offer mechanical suction relief valves to adjust suction. So it's easier to just show the single amperage of the motor (12 amps, etc). Before the 1980's, our canister vacs were rated by horsepower - with 3 or 4 HP being quite powerful. Can't remember how horsepower ratings are derived, though.
Peak HP Ratings Are Mostly
Completely made up numbers unfortunately. ShopVac still uses them BUT, they have to report actual steady state HP/Amp ratings as well.
1 HP = 746 Watts, so the max steady state HP any North American machine could have plugged into a standard 15 Amp outlet would be 1800 Watts / 746 Watts/HP = 2.41 HP. So when you see anything higher than about 2.5 HP, you know it's based on a peak turn on current surge that lasts for just a few milliseconds that won't pop the breaker. But I'm very glad that those ridiculous peak HP ratings are largely gone now along with the equally useless "Cleaning Effectiveness Per Amp" ratings from the glorious 80s and 90s.
Also, how much power a vacuum uses has pretty much no relation to actual cleaning power, usually expressed in CFM. If manufacturers would post CFM at the hose or nozzle, consumers would probably buy different machines pretty quickly.
Imagine a 12 Amp (1440 Watt) clean air machine that only produces 50 CFM at the nozzle that sells for $800. Then compare that to a cheap $70 machine produces 80 CFM at the nozzle. Which one would fly off the shelves now?
Bill
Amps is the current that flows, watts is the amount of power the component is using.
We have always used watts in the UK. We use 240v in the UK. So 1000w will have a current of 4.1 amps.
And I agree. Manufacturers should be forced to provide the CFM at the end of the hose or it could be part of the EU test over here.
