I just watched a few you tube videos and came across a couple ideas.
I'm going to use Kirby for explanation purposes. Kirby has a brushed motor. The brushes create carbon and dirty the vacuum. Brushless motors have no carbon output and are far more effecient and last longer. You change the Kirby brushed motor with a brushless motor.
The second part is to do with power. The Kirby runs power through a cord. If you took out the cord converted the vacuum to battery power. I know there's advantages to both. Lithium if managed right can provide the needed power without the overheating issue. The vacuum could have 3 or 4 batteries and once one heats up switch to the other battery. If they can run lawn mowers on lithium ion batteries why not use that technology with vacuums.
I know there are good battery powered vacuums out there. I'm thinking it would have to be robust to move a heavier vacuum.
Imagine a brushless motor no emissions released. More power and last much longer.
I'd think you could put batteries in motor housing or maybe a pack on the side.
It could be done by someone with money knowledge and patience.
Which do you guys think.
