Vac Recommendations
ocscott3085
DMV
Hi Everyone,
I was wondering if I could get some help from you all in deciding on a secondary vacuum for my home? My 4 month old house is about 4,000 sq. ft without the unfinished basement so there is a LOT of floor to clean! My main level is all hardwood floors and wool area rugs with the exception of my family room which has a frieze carpet. I also have a dog who sheds and loves nothing more than to climb up on every sofa when we're not home and leave evidence behind. It's a good thing she's cute!
My main vacuum is a Dirt Devil 990 Pro Series central vacuum system with the Wessel Werk Edge Power nozzle. It does an AMAZING job deep cleaning the rugs...if you hold the hose up to your ear you can hear all sorts of crap going through it. However, when I just want to clean the sofa, family room rug, and kitchen...it's a bit overkill to get the vac hose from the garage, clean, switch outlets twice(not the best placements done by builder), and wind hose back up to put away.
So, I've been using my Miele Twist upright in between weekly cleanings to keep things spruced up. The Miele has great suction but I don't think it does the best job grooming the rugs despite the kuddos from Consumer Reports and my excellent previous experiences with Miele vacs. It's also fairly heavy and requires expensive bag/filter replacements. With that said, I'm thinking about selling it if I can find a suitable replacement that would
-deep clean rugs well and have a brushroll shut off to do a quick clean of bare floors
- have an on-board hose to clean dog hair off the furniture
- inexpensive bag replacement or bagless with filters I can clean myself
- if possible - no disgusting dog odors when cleaning
- prefer to keep it under $300
I know, this has been quite the list of requirements but I figured this is one of the best places to get sound advice. Thanks in advance!
Thanks so much for the recommendation! I have read good things about that model with the exception of belts slipping. I think I may want something a little less bulky as that's one of the more annoying quirks of the Miele Twist...that IS a bulky machine!
That's too funny...actually saw that Oreck on tv this morning. However, it doesn't have a hose and dog hair quickly gathers on the sofa. My parents had an Electroux Epic 3500 when I was in college and I remember it worked well but again, no hose. See why I had to come to you guys...who knew this would be so tough haha
I always say this, go to a good vacuum shop and have a look for yourself, try them out yourself, asking some one what vacuum to buy is like asking some one what car to buy, you need to try them out for yourself. Some people Love a Kirby and think its the best vacuum ever some find it to heavy and think a rainbow is better, the best way to choose a good vacuum is to go and try them out for yourself, If you look after it even a $35.00 Bissell will last you a few years
Panasonic Canister
The Panasonic MCCG902 is a basic trusted design canister. Lots of suction, strong agitation. 4 on board tools. Standard universal hose end will also accept most other manufacuters attachments to include most likely all of your Dirt Devil Central vacuum attachments. The Kenmore/ Panasonic electric hose will also accept the PowerMate Jr. You can get them new through Panasonic or also find some on eBay and most likely your local vacuum store as well. Hose grip has 3 way on/off switch to control all motors and turn off power head as well. You can keep the power head attached to its own wand system and most likely use bare floor wand set from your central vac. There is a quick disconnect system on the wands with the powernozzle but I recommend using a separate set of wands and not using that connection all of the time as I would recommend with any manufacturer with a quick disconnect. It's a nice convenient feature but something to potentially go wrong in the future as well.
The Panasonic will utilize a variety of bags from several manufacturers available in Micron paper or HEPA cloth. It will fit Kenmore and Panasonic canister bags.
Another option, its on eBay now, but often the Royal Lexon SR30020 canister vacuum appears on eBay at $300 I highly recommend that vacuum but its regular retail price is about $500.
http://www.vcdiscounter.com/mccg902.html
I would like to add my support for the Panasonic 902. But I'd like to suggest some USED high-end machines like a Filter Queen, Tri Star, Air Storm or Air Way.
Justin
If you don't mind the expense, and you really want a multi-surface vac that is not bulky like the SmartVac, you should try the Sebo Felix. It's an upright that can be turned into an over the shoulder canister and you can get a variety of attachments to suit your specific needs. Not sure if it will deep clean like the Panasonic 902, but it's worth a try! :-)
Consumer Reports has listed the Sebo Felix Premium as a "Recommended" buy. Though it costs about $600, it really is a great sleek easy to use vacuum. Here's a summary of what they discovered during testing:
CARPET CLEANING: The Sebo Felix Premium does a very good job of removing the embedded mixture of sand and powder from our soiled test carpets. This is a measure of how well a vacuum removes the dirt hidden deep in the carpet and not visible to the user's eye.
BARE FLOOR: The Sebo does an excellent job of removing sand from our vinyl floor, leaving very little behind and not scattering sand across the floor.
PET HAIR: This model does an excellent job at picking up pet hair from carpets using its power head. The visual inspection of the test carpet following the pet hair test reveals no traces of pet hair left behind and very little pet hair caught in the brush roll.
USABILITY: This unique and light design with a swiveling head makes it easy to maneuver and clean under furniture. Its method for changing the bag is also a plus as it is easily installed from the top of the vacuum. The on/off switch also controls suction with a convenient slider on the handle. The manual carpet-height adjustment that allows for a better match to the carpet is a dial on the power head that requires the user to bend.
Here's a nice Youtube clip showing some of the features of the Sebo Felix Premium. You can buy an optional extension hose and mini turbo nozzle to do your furniture with ease. Love the expandability of this versatile vac!
Orange Kenmore and Red Panasonic are a little different!!
Red Panasonic MCCG902:
--Larger bag capacity
--4 piece original Kenmore attachment set--upholstery nozzle is full width and has firm bristles that are great on pet hair
--CT18DX power nozzle
-- Much better grade plastic
--Numerous Panasonic Authorized Warranty Dealers
--Full front access carry handle on canister.
--Full wrap around absorbent furniture guard on suction unit
Orange Kenmore 29319:
-- Air driven mini turbo brush included
--3 piece attachment set, to include cheap version combo upholstery & dusting brush. bristles on this dusting brush feel like agitator bristles they are not for delicate dusting by any means. Upholstery nozzle is quite small with no bristles, rubber fingers or even grooved plastic to better grab dirt.
-- CenTec CT20DXQD power head-- many complaints of rear wheels breaking off rear axle
--Suction unit carry handle is awkward-- grab from bottom only
--Primarily Sears only for warranty repairs
Both machines use the same bag, but the compartment on the orange Kenmore is smaller and will only allow the paper bag to fill about 2/3 of the way, the rest of the bag has to be folded in to fit. The red Panasonic however, the bag compartment is actually larger than the paper bag, Kenmore HEPA bags are huge and work well in this unit.
Here is a link on eBay to the Panasonic MCCG902 predecessor. It is model MCCG973. Brand new in box in this listing. Same vac except for color and power nozzle. The power nozzle on this MCCG973 is the CenTec CT14DXQD. This power nozzle is liked by many in the industry. It was around in the 1980's, they have made some tweaks to it with motor changes, cogged belt to serpentine belt, ridges in front for better airflow and new wooden chevron designed agitator.
Another option, pictured below is: If you want more features you may also look to the Panasonic MCCG917. This can be still under $300. It is rated to be a quieter unit from the 902 with a new design from Panasonic where the bag sits in a removable basket inside the bag chamber to allow more continuous airflow. Also includes air turbine hand tool, variable speed motor, and aluminum telescoping wands. Combo upholstery & dusting brush instead of 2 separate.
http://www.ebay.com/itm/Panasonic-1...970&pid=100015&prg=1006&rk=1&sd=140893319575&
