Hi All -
Just looking for opinions on something - Not looking to start a battle over a product...
We have all white wall to wall carpet in our home, that is now 23 yers old, and still white...
We also have a dog, and cat.. and up until last September had two Cats... (RIP Buster...)...
I keep the carpets perfectly white using two things - A Rub doctor Mighty Pro X3 that we do the entire house with once per year - And then 3-5 times per year, I use Dyson's Zorb Carpet Powder... I found it better then Capture in that it is a larger particle that does not destroy the vacuum quit as fast as less passes through the bag or cyclone...
The ONLY downside to Zorb is the scrubbing it in by hand, when doing the ENTIRE house... The instructions from Dyson always showed either using the Zorbster attachment on the correct EU Dyson which we never got, Scrubbing it in by hand with a brush or the Zorb attachment, OR taking the bin off of the Dyson, and using the Power Brush Nozzle with no suction -
I was thinking last night, Since I have three of the Hoover Air Revolves left in storage (Gave 2-to my nieces) I could take one of them, install a small rocker switch to cut out the suction motor, and still allow the power nozzle to run and brush in the Zorb...
Do you think the brush on the power nozzle would be as effective as scrubbing it in by hand?
I would make up some sort of "PLUG" to block the opening in the brush head so the Zorb does not build up in the intake opening -
I would clean the power head throughly after use so as to prolong its life - I could also then dedicate that one Air Revolve to exclusive Zorb Carpet Cleaning...
Thoughts... Thanks in advance - Dan
