U4403 Zipper Puzzle
rotary01
maryland
My bag zipper pull became separated from one side of the zipper when I was trying to change the bag this morning.. guess i pulled it down too far.
How on Earth do I fix this? I tried restarting the zipper from the inside but it doesn't make it around the plastic bag clamp. I cant rotate the clamp ends in any way to allow it to pass by. Do I have to bend the zipper open? This must have happened to someone else.
Please any advice and I would be grateful.
Mitch,
I’m sorry I can’t help you. But, I have a vintage Eureka, and the same thing happened.
Like you, I’ve tried everything I could think of, and I just can’t get the zipper back on track.
Zpper fixed
Somehow I fixed it.
I expanded one of the zipper pulls openings, and ran the zipper pull, one side, from the bottom around the clamp to the top of the bag.
Next, pushed the pull over the other side of the zipper. Squeezed a couple zipper tongs together and pulled it down past that point.. Squeezed zipper back together when I was satisfied it worked. I also lubricated the zipper with candle wax.
It helped that I had another similar Hoover so I knew which end of the zipper pull was up ;-) Will be much more careful and make sure handle is released (might have been problem) in the future.
