So, I was thinking of maybe adding a couple of two motor central vacuum units to my collection, I don't use piping, I just attach a utility valve to the unit and use them as very powerful canisters. Does anyone have a unit with two motors, and if so, do you notice a big difference in performance? I don't have a 220 volt outlet, wish I did, then I could get the super duper two motor units, so I'm limited to the two motor 120 volt models. With a two motor system, the motors can be installed in series or parallel. When in series, the suction is increased, when in parallel, the airflow is increased. The majority of two motor units seem to have the motors installed in parallel, probably to avoid having the heated exhaust air from the first motor going in to the second motor. However, with two motors in parallel, the airflow will still be restricted by the hose and attachments. So, for anyone who has used a two motor system, do you notice a big increase in performance? I've read a few articles and they seem to think that two motors in many cases is not as good as one large motor.
I'm wondering if anyone can identify these power nozzles, I'm thinking they are just rebranded nozzles from other companies, this first one is called the deluxe comet.
http://www.thinkvacuums.com/central...s/deluxe-comet-electric-powerhead-silver.html
Then there's the premium galaxie power head
http://www.thinkvacuums.com/central...rheads/premium-galaxy-electric-powerhead.html
