The print is currently in PLA plastic, though I have been thinking of experimenting with mixing other materials
I had been thinking about making a sand mold and using molten aluminum to create stronger impellers, but at the same time, I'd like to share it with others, and this would cause the price to be sky-high.
On another note, I finally got the impeller blades to break when I sucked up a rock. I'm going back to the drawing board with this design, and will likely have the base of the impeller in PLA still, but print the blades in semi-flex filament (semi-flex is practically indestructible...seriously).
I was going to attempt to make a YouTube video demonstrating the different things I subjected the poor impeller to, but...I made a mistake early on that caused a LOT of cat food to be flung around my work station (don't worry, there was a bag on the other end)
