This is Why Kirby Says to Empty the Bag Out After Each Use
kirbyclassiciii
Milwaukie, Oregon
The picture you're seeing suggests why Kirby recommends to empty the shake-out bag after every single use of your machine.
I vacuumed my house today with my Classic III. It emitted a strange grating sound in the motor, and I think these tufts of hair around the fan blades suggest why.
Lesinutah
Les,
Yes, I totally agree!
I do know for certain that a disposable bag past half-full would restrict suction, thus causing all this hair to be stuck around the fan. This is what you should also pay attention to.
Hey
I do watch bag fill after every vacuum.  I'm ocd I clean off brush roll wipe down with baby wipe.  Empty emtor tray.
I make sure seals are good.  Good lesson for everyone who likes vacuums.
Well they mainly say it because of the fiber material the bag is made from can collect bacteria and mites within the weaving, but if you get it too full it can fall back down through the motor as well too.
Oh-h-h-h dear lawd-dy
well, that wasn't as bad as I thought it would be.
Just think of A-LL the people you and I know DON'T empty after each use.
When I used to have canister or uprights, I would always remove the bag after each use, put it in a plastic shopping bag, and carefully store it in the freezer. This was to freeze and kill the parasites, bugs, germs,.... whatever. And, the vacuum gave off a nice "clean freezer" smell, next time you vacuum.
I'll only use a vented central vac now. The suction is great and having all the dust and heat and chemical off-gassing and whatever else expelled outside keeps one healthy.
But hey, It was a long time coming to that revelation.
This is something that happens with fan first machines. The hair may be longer and it just gets trapped between the blades of the fan.
Not so much a defect, as just a need for regular maintenance. If you know you are vacuuming lots of hair, you may have to do it more frequently. As others said, if there are nicks in the fan, it can cause the hair to get stuck more readily.
I've already seen this post on Facebook. Like others have said there is probably a nick in the fan and hair is catching on that nick. I've seen this before in Kirbys with nicks in the fan blade. Mostly on Heritage II machines with the gray fan.
I don't think it has anything to do with emptying the emptor unless the bag is so full that dirt is backing up into the fan chamber.
greatvacs28,
what a engenius idea that is to freeze the bag....thus halting bacteria growth/food fermentation etc . thanks for sharing that idea!
Kelton
Kirby plastic fan...
If your older pre-G5 Kirby has the Gray plastic Lexan fan, you should replace it ASAP with the newer White Amodel fan! The Gray Lexan fans crack with age and could fly apart causing major damage to your Kirby.
rivstg1
"..a engenius idea that is to freeze the bag..."
Thanks but I can't take the full credit for this. I was reading about people wanting to sterilize their kids toys and stuffed animal. They said put them in a plastic bag and put it in the freezer over night. boom
Logically, that would work for other things as well. I also freeze my compostable scrap food items to help break the cel walls before composting. It also helps to keep flies away.
I had a long-haired girlfriend who shed so much that her hair would clog up my Kirby's fan 2-3 times before I finished with the carpet. The belt would slip and the noise would increase. To her defense I was vacuuming once a month then. Empty bag or not, too much debris at once can get stuck in the fan or wrapped abound the spindle. She was proof of this...
I remember stopping the Kirby one day and she asked me what I was doing with the nozzle off and a knife in my hand. She watched as I cut a big glob of hair off the spindle. I gave it to her and told her that she gave the vacuum a hairball. She blamed the cats I never had...
Luckily, removing obstructions like this from a Kirby is easy. Imagine all that hair getting stuck in a cyclone chamber!
She clogged up the shower drain on a regular basis as well. I am surprised she never went bald!
After she moved on, I never had such problems anymore, even when vacuuming every 4 months!
Hey
If I remember right this is a metal fan not grey lexan. If metal caught on fire let's just say unless you are sucking up burning colles with sealed chamber is almost impossible. His bearings in motor could spin out pop off bag but he isn't going to burn down the building.
Ben
I'm wiring tradition back to stock. My d80 single speed. I gotta g series hose cut off small lip and glued on d80 adapter.
My tradition was made in may of 82.
Hate to break it to you, but freezing does not kill bacteria, it just puts them to sleep. I suppose at the very least, it would prevent it from festering while frozen, but as dust tends to be very dry, bacteria wouldn't be able to propagate anyway.
I'l TAKE it
Sleepy bacteria is better than ones copulating pointlessly waiting to escape the paper bag and be shot out the exhaust holes of the vacuum, anxious to be inhaled by an innocent human or allergic aged cat.
Actually, freezing can do quite a bit of damage, so I've heard. It doesn't kill everything, but quite a bit. Entire animals for example.
yeah,
the freeze can kill the dust mites....that eat our skin cells....also, would keep the food particles that were sucked up from feeding organisms thus....smells
lots of stuff can go in freezer. As was mentioned, kids toys. People put those frozen ice/hot things in there.
You wouldn't throw out a vacuum bag after one usage. One puts it in a plastic bag to keep any latent dust contained. I've never had a problem.
It works great. It's easy to try. I like that fresh smell that comes out when you replace the bag in the cleaner and start vacuuming. Much better than musty moldy yuck that some people get.
I mean, I don't see any harm in it. And it's not like something harmful you're putting in the freezer with the food, it's just dust.
just dust..... and stuff
in a paper bag, which is in a plastic bag, and it gets frozen.
Teddy bears get frozen when they get put in a plastic bag too.
I've always wondered what that blue gel is in those cold packs that one can use for therapeutic purposes. It's not popcicle water, that's for sure.
I may have solved another part of this large problem: always clean the brush roll after you're finished using the Kirby. Left unchecked, too much hair and lint around the brush roll will make it a bigger problem and thus reduces cleaning efficiency, and later on will cause all this hair and lint to get stuck in the fan chamber.
That's true for any ...
"....always clean the brush roll after you're finished using the..."
power nozzle, or for that matter any brushed attachment like a floor or dusting brush.  It's like this: when one uses a paint brush, tooth brush, vegetable brush, etc.  you clean those (or should be).  The same goes for a vacuum brush.  Failure to remove old hair and string only inhibits a vacuum brush and can damage the roll or possibly the power head.
Here's some pics of my reconditioned 1983ish Kenmore double-brush power nozzle.  I wish I had the "before" pictures.  I got it with some other vacuum parts and I don't think the seller even knew what it was.
It looked really bad.  It had a big spot of paint dripped on the top, was dirty from sitting many years, the neck was cracked (though oddly still useable), the cord was pulled out, there was so much sand and lint in the motor it made a horrendous sound, and the brush roll was just covered with string, a couple of pieces of thin guage wire, hair, and who knows what else.
After thoroughly taking it apart, soaking plastic parts and carefully cleaning, removing all the gunk from the motor and lubricating it, and of course taking a scissors and cutting length-wise and removing all the junk on the brush roll, removing and cleaning the brush strips, etc. . it now functions and sounds as it should.   The brush roll is black painted wood, which was scrubbed and waxed; but look at the paint worn off by the stuff that was on there.
It still bares the scars of damage done.  How in the world could someone not know there was something wrong with what they were doing?  Look at the gouges in the plastic underneath.  Thank-fully, those don't affect cleaning or suction.    Incredibly, it still has both of the thin plastic support bars that are known to break.
Always clean your brushed attachments after each use.  It only takes a few seconds with the wand of the hose going back and forth over the brushes.  And a brush roll with string or long hair wrapped around it will often clean itself if you simply cut with a scissors, length-wise through the mess, and then vacuum a few strokes on carpeting.  The brush roll can throw off the cut pieces and suction takes it away.
I love taking stuff like this and bringing it back to full functionality, or as close as it can get.
Clening brushrolls after use--the hairs,strings,threads can get caught in the bearings at the ends of the roll tearing them up-and the housing,too!And for canister powernozzles-puts a stress on the motor and belt.They can overheat.The belt will break and the motor can burn out.
