Hey
I've posted I'll be doing airflow and voltage tests soon. I have my 3 prong emtor f&g bag done. My 2 prong f&g needs spring and it's ready. I already have 2 prong emtor hepa conversion and 3 prong hepa conversion.
My 3 metal mini emtors 1 tradition 1 classic and I haven't checked stamping but another metal mini emtor almost finished. I just have to get 3 PVC pipe coupler/adaptors. Once that is done I just need to connect tubing. Everything is glued or. Adhered to emtor. They are air tight seals too.
I'm not making mini emtor f&g I may try 3 prong but don't think it will fit.
I have shakeout for 2 prong 509, e prong 562 d80 classic and tradition.
Prior test shakeout empty bag performed best. Hepa was real close behind.
I used 562 and tradition.
The f @g bogged down 22-35%. Half full shakeout significant loss but still higher than f@g empty.
I'll try to get tests done soon. I have f@g royal and type b royal to test.
The bags are almost complete.
My d80 needs power switch I just found. Classic needs 2 washers and fan put on.
I'm going to try to put in Excel spreadsheet.
I'm also using voltage meter seeing if motor is affeced.
