quebecois
I'm at the beginning of the process of cleaning the motor of one of my Super J's, actually the one that smells weird when I run it.
As can be seen on the first picture, the motor was very dirty, I mean, real dirty, and this was probably enough to make it smell weird when running.
I'm planning of cleaning it thouroughly though, and to achieve this, I have to take it apart. I followed the instructions on another thread (thanks to Nathan Thomas), now I'M at the stage of removing the fans.
I unscrewed the 3/4 inch nut that holds them, but the fans don't want to come off. Should I just put a bit a WD40 on the shaft and pull stronger?
Also, I'm a bit concerned about what the inside of the fans housing look like (2nd picture). All these spiral scratches mean that the tabs of the bottom fan touch the housing, is this caused by a worn bearing?
Brushes still 1 inch-long are still good or should I change them?
