Air-Flow VS suction
Suction is also knows as water lift. That's the pressure that the motor's fan (or fans) develops. Air-Flow is the amount of air moving through the machine. The filter (or bag) will restrict the airflow through the machine, as well as the clogging effect of dirt. SO, a vacuum that advertises good airflow ratings, can ONLY do so for a moment, when brand new. As soon as dirt is inhaled, the airflow begins to diminish. Airflow picks up dirt, suction (water lift) is the pressure to pull it quickly into the machine. Some vacs have great airflow with low water lift (Rainbow). Some have great pressure with low airflow.
The truth is: if the vacuum has good airflow and water lift, then it will clean well. IF the machine doesn't lose its airflow (Rainbow, Dyson, etc.) then it's an excellent machine at cleaning CONSISTENTLY. A vacuum with high airflow and water lift at first, but clogs quickly (Hoover Windtunnel 2 bagless) cannot continue to clean well for a long time and will, in fact, stop cleaning deeply very quickly. Hence the reason that Electrolux told us (in the model G's owners book) to change the bag before EACH USE.
