swampymarsh
Just picked up this vacuum from a dumpster this evening and went through it to make sure it was all there before I plugged it in. The bearings and wiring are all good however the brushes are pretty nicked up and the armature (I think that’s what it’s called that the brushes ride on if not correct me) has some loose teeth? (I don’t know technical terms) the little copper pieces that make it up some of them are loose and breaking away the carbon brushes which causes sparks and arks which is making it smell like it’s burning. I wasn’t sure how to tighten up these copper “teeth” or if there was a way? Not trying to use the vacuum just trying to make it sound a little better and maybe not smell like a house fire
. Thanks.
