Simplicity Freedoms found!
blackheart
North Dakota
So i've been lucky enough to find, not just 1 but TWO simplicity Freedoms recently
The one on the left is the newer styled S10s. It was traded in because it would come apart in use, it was missing a clamp that went between the handle and the fan case connection. It's a little scuffed up but it's nothing a new hood wouldn't fix. It's been pulling a good amount of debris from my carpeting i'm kind of shocked really, i've used every vacuum I own on this carpet and this 8-9lbs vacuum is still finding all sorts of grit.
The other i just picked up yesterday, a commercial F3300C. A fellow collector informed me of it at a local thrift shop, after asking him a few questions i was out the door. It's in pretty good shape for a commercial machine the grounding prong is missing and the belt needed to be replaced but other than that it seems like it was very well cared for.
Congratulations on the Simplicity finds. The S10S model uses a different fan and fan housing than the 'old style' F3300C. It's an awesome deep cleaner and one of our best selling models.
I spy what I think is a Water Matic to the left of the S10S.
You are correct
That's a 2008 edition Filter Magic/Water Matic
With the redesigned fan does the newer version have more airflow?
