Shopvac 16 gallon on duty
Impressive
Your long hose and it performs that well is impressive. Yours looks like rigid orange shop vacuum. Mine is a 12 gallon craftsman red. I bought it before craftsman went belly up.
My Shopvac is a big big berta .
At 6.5hp 60,5 liter 16 gallon thank , with drain and blower port on the back. The reason the long hose is so good ,the machine came form the factory with a 2 and 1/2 inch hose , so its allready made for the big tool set.Also you will see that , each connection is tape and that is preventing air lost or water leaks .Thats always been shopvac big tool kit down side, the connection are not seal.So that fix that and yes shes my big berta huge mest cleaner uper monster hahaha.
yeppp
yeppp use the shop vac to drai nthe shink and vacuum the clog and clear the pipe works like a charm cosst 0 and my shink drain normal now should of seen the muck in the thank .Water in one side vacuum on the other side and presto 0 clog .Cheap and easy n o tools premitive but it worked .
