shes here my Olympia one
There’s usually Plenty of Sidekicks on eBay
And if you still have your Discovery upright, you might be able to use a Sidekick with it. You’ll need an electric hose AND it depends on which model you have. Not all of the uprights have a 2 prong outlet in the back.
I  have a  question for yall  here  pardon me if  some one ask already  :,
but  do i  need  a  pre motor  filter for my  olympia one  or good with just   the  bag  and  no exhaust  filter  also  ,   first time owning a  1401.  I do  use  4  ply  bags
As  my  zb 89 had exhaust filter thanks  .
That’s the difference with the Canadian models….
There’s no way to use an after filter on an Oly One. Electrolux didn’t make models with after filters for the U.S. until the plastic bodied tank was available in 1985. Can’t remember for sure, I want to say that it was called the 2100.
Discovery and SideKick
The Discovery II and Discovery III did not come factory equipped with a power outlet for the SideKick, but there's an adapter kit that came out for the Discovery III that will also work with the Discovery II to add the necessary connection. I put one on my Discovery II. It's a pretty easy install. The adapter is a trapezoidal piece that fits where the wall cord plugs into the vacuum, and provides connections for both the wall cord and the cord for the SideKick, which is also included in the kit, along with a metal-tipped hose handle to replace the all-plastic one that would have come with the hose, and a set of straps to attach the cord to the hose. The adapter has a switch that turns the SideKick's side of the adapter on and off. It can get kind of confusing if the Sidekick you're using also has an on/off switch. I'm not sure whether they're still available through Aerus dealers, but they show up every now and then on eBay.
