I recently acquired a 1CR and had done my usual disassembly and cleaning. When reassembling the machine, one of the screws that holds the rear axle to the motor shell sheared off, almost flush with the hole. Common sense says to use an extractor but this is a real small screw and I've already checked, the smallest extractor still is almost as big as the diameter of this screw. Am I screwed (no pun intended)? I'm not sure if I feel comfortable drilling out the screw, being that aluminum is a pretty soft metal and it's entirely possible to make a wrong move and ruin the extrusion that the hole sits in.
Also, off topic ~ This is the very first time I've washed/submerged an armature and field. Always wiped down with a rag dampened with rubbing alcohol but this motor was filthy and smelly. Washed it in Tide liquid and hot water -- didn't scrub but rather swished it around after a soak for a few minutes. Rinsed well and fully dried of course. Bearings were going to be replaced anyway so I didn't care too much about them. Anyone else wash motors? This machine was FILLED with dust and dog hair, even inside the motor. Smelled like it too. Now even the field and armature look and smell new. Was I wrong to do this?
