This is my second issue....
I have a X1 (old version in blue) I ordered up a new servo as the cocks had failed in the previous one and it was just dropping.
The new one arrived, simple enough to install and connect (haven't used the machine for a very long time since this wasn't working as far as I know all was fine).
Magnet is in the side, servo connected and switched on. Raises to the highest point, then you attempt to move the machine but it will not move.
Place it back in the upright position and you get the flashing red light of check roller.
Swapped out the servo again for the old faulty one to see if it was that, the same thing happened.
Did I do something wrong installing it? The magnet is on the side of the swivel neck. What else could cause an issue?
