Roll O Waxer
kirbyds80
California
What is the thing for and how does it work?, And when was it made/discontinued and will someone upload a picture of one?
Thanks,
-Jayson
The rollowaxer was used to apply wax on the floor for buffing. It was on a long pole, and looked very much like a paint roller on the end. It sat in a plastic tube.
Kirby had a version that was a flat pan that you connected a pole to, that sat in a dish when not used.
Im sure there -may- be stuff like it out there today for floor polishers, but not really 100% on that.
Can a picture be put up
If all possible can a picture of one of these be put up? If anyone has a Roll O Waxer please upload a picture.
-Jayson
Interesting part
This is cool, but I think the Miracle waxer that can be bought for G Series models is a lot easier to use and you can remove the roll and put it back in it's packaging.
-Jayson
I'm not totally sure but I think my mother had a Roll O Waxer briefly back around 1960 or so. It was for applying liquid wax on linoleum floors and might have been sold alongside the Johnson's wax in stores. Try searching through vintage advertisements for household products.
Basically it was a broom handle with a quart sized dispenser near the bottom which fed the wax out onto a rolling pad, much like a paint roller. I remember there was a hood over the top of the roller to supposedly prevent splashing as you rolled it back and forth. I don't think Mom used it for long. I think it was too much of a hassle to clean up after using it. Mom didn't use the liquid wax applicator on her Montgomery Ward buffer for the same reason.
Hey Brandon,
The waxer you have pictured is a Handi-Waxer that Kirby replaced the Rollo Waxer with around the time the Sanitronic came out. To use the Handi Waxer, one would put a pouch of Kirby Carnuba (sp?) in the waxer, and slit it open with a knife at the bottom. The cap was used to keep the wax from drying out between waxings. The canister wands were reversed (straight wand on top, curved wand on the bottom) and inserted into the top of the waxer to make the handle. The user would step lightly on the top of the waxer to squeeze out the desired amount of wax, and then apply it to the floor. One would then attach the Miracle Head to the Kirby and buff the wax out to a beautiful shine. I've seen pictures of the Rollo Waxer in older instruction books, but never actually saw one in person.
