swampymarsh
I just recently picked up two old Rexair vacuums, one is a model B and one is a model C. They both run, the C runs great, however the bearings on the B are going bad due to age and moisture. I've been trying to find what little info i can on these things and possible part numbers and was hoping someone out there might be able to give some advice or lead me in the right direction. I'm also not sure if there's just bearings or if there's also bearing seals i need to look for. On the off chance that someone reading this has done this same operation if you might have any advice as to how to go about removing the old bearings, i've got an idea but any tips would be greatly appreciated.
Marshall
Marshall
