Replacement parts for a GE Central Vacuum System 1970's
nicholi117
New York
I'm looking to find replacement parts (original if possible) for a GE relay P/N 3ARR4BA32 and the transformer.
I'm not sure if I should upgrade to a circuit board or try finding replacement parts.
This GE Central Vacuum System model number BGVS600A9A was built in the 1970's.
Thanks for your help,
Nick,
Your GE was built by Beam as a private label (even though the relay was ironically a GE part).
It's quite easy to find a relay that is electrically compatible (search Google for "Beam 294 relay" to see the one that they used in the 80s until they went to circuit boards).
Finding the exact identical one will be tougher. If I come across one, though, I'll keep you posted!
Replacement filter
Thanks for your reply back.
I have another question, it seems the cloth filter installed on the GE (Built by Beam 253) is glued on. I don't want to remove it, if there's no replacement filter for this vacuum?
