I'm revisiting my free Electrolux Automatic E. It needs a lot of work. But, for now, I figured I'd put a little more time into making it look as nice as possible.
It has quite a bit of paint transfer, from previous owners bumping it into painted walls, trim, etc.
When I encounter this on plastic vacuums, I've had a lot of success using rubbing alcohol. What I'm wondering is; can I do the same on the painted metal Electrolux, or will the alcohol damage the vacuum's factory paint?
I've done one side of the machine using white rubbing compound. It did a decent enough job. But, requires quite a bit of elbow grease. I was just wondering if I could possibly save myself a little time and effort by using alcohol. And, I figured I'd check with those more knowledgeable first!
Thanks!
Thanks!
