Rainbow question...
kirbymodel2c
Nottingham, England
Hi, I managed to get hold of a Rainbow SE vacuum cleaner.
I got hold of the turbo head manual but not the one for the machine its self.
So when you fill the water basin up do you have to fill the water up over the plastic pin thingy in the middle of basin??
Also when do you know when you have to empty the machine when it is "full"??
I've never had one before and there not common over here in the UK so any help will be great:o)
Thanks James
Thread Number: 9781
Yes, you fill the water up to the top of the spike or pin in the water basin. That's what my Rainbow instructions say to do. If you fill it too full, the vacuum will shake and can be damaged or ruined if it tips over. If you are using it to suck up water or liquids try not to let the liquid go above the pin as well. Hope this helps!
