It sounds like
Your brushroll is incorrectly assembled, The compression washers go in between the roll caps that are tightly fitted to the roll and the bearings, then the endcaps are screwed to the rod ends, screw them tightly in opposite directions. Also for your clips, just bend them slightly towards the bottom of the cleaner and they should hold fast. Hope that helps.
