moderneezer
Hello everybody!
Back then, I posted an thread about upgrading a straight-suction canister to allow compatibility with a power nozzle and artworks related to the subject. This thread is going to be focused on the wiring in the canister and the electric nozzle cord.
I haven't finished secondary education yet, let alone obtained a bachelor's degree on anything, but I have the feeling that I could predict how the wiring should be and the diagrams are based on my theory.
The two artworks show the wiring in the canister and the power-head cord (the latter only in the second picture) when the tank's plug is polarized. A plug is polarized if it can only be inserted one way into the outlet with the hot contact always connected to hot and neutral always connected to neutral.
Look at the second picture. The electric flow from the socket, going through the black wire which is the hot one, would pass through the on/off switch on the canister and, before heading to the tank's motor, would go into the PN cord and through the first on/off switch on the switchboard latched to the handle, then at the node where the flow would split. One flow would go into the black wire with red strip and to the canister's motor while the other flow would go through the second on/off switch and to the nozzle's motor. The flows from both motors would go through the neutral white wire (shown in grey in the large picture and in white with grey outlines in close-ups), merge at the node in the tank and return to the plug socket.
If the canister and the PN cord were sold in Britain, Australia or other countries where the plugs are similar to those in Britain or Australia, the wiring would be arranged the same way as in the diagram but the hot wire would be brown, the neutral one would be blue and the black wire with red strip could be brown with a black strip instead. The electric connectors for the power-head would be different to prevent a mismatch between a 120V nozzle bought in USA or Canada and a 230-240V canister.
