A ajr2993 Active member Joined Mar 18, 2022 Messages 25 Location Bakersfield, CA Oct 25, 2022 #2 The main question about central vacuums is if I pair 2 central vacuum units I get better suction. Is this true?
lesinutah Well-known member Joined Aug 26, 2017 Messages 5,479 Location Utah Oct 25, 2022 #3 If You get around 150 cfm of suction from one central vac why would you need more power?
A ajr2993 Active member Joined Mar 18, 2022 Messages 25 Location Bakersfield, CA Oct 25, 2022 #4 Because I like power!
T tolivac Well-known member Platinum Member Joined Aug 25, 2006 Messages 7,303 Location Greenville,NC Oct 26, 2022 #5 You can only force so much air thru the opening-hose,pipes you are using.After that the power is just wasted.
