ParticleScan Precision Laser Airborne Particle Counter
chicagomike
Plover, WI
Overview
The ParticleScan Lite features low cost and high sensitivity, making it a powerful tool for sales professionals, service technicians or others who conduct air filtration product and efficiency demonstrations. With a detection range down to 0.3 microns, the ParticleScan Lite provides exceptional value. It is designed for the detection of airborne particle concentrations in normal and polluted indoor environments. The ParticleScan Lite is ideal for demonstrating the efficiency of air cleaners, air filters, and vacuum cleaners.
The simple on/off functionality of this handheld scanner, combined with single-channel particle counting, make it ideal for many air quality professionals who want accurate results and ease of use at an affordable price.
Applications
The ParticleScan Lite is a powerful, yet affordable, IAQ tool that supports simple and accurate air quality testing. The scanner has the same particle range as other ParticleScan models, but its simple controls make it perfect for sales and service professionals
Show the efficiency of filters, air cleaners and vacuum cleaners
The ParticleScan Lite is easy to use for testing the air at the intake and outlet of an air cleaner, air filter or vacuum cleaner. Use it in the showroom or in the field.
Inspect HVAC equipment and ducting
The ParticleScan Lite detects particles down to 0.3 microns in diameter every six seconds, so it provides continuous readings wherever and whenever needed. The ParticleScan Lite makes it easy to quickly demonstrate air quality problems and solutions in the showroom and in the field.
http://d7.iqair.com/commercial-laser-particle-counters/buy
