Numatic WV470T Cooling Fans
numatic_boy
England
Hi guys.A few of you might know thag I have a pair of Numatic WV470Ts that have damaged cooling fans.I want to find a UK based supplier of these fans.I already found a US supplier but the fans that I found were labelled as Rainbow parts so Im a bit skeptical about fittment.I will attach picture of the part needed,motor and vacuum.I am appreciative of any help.
-Adam
Well, you know Rainbow does not make motors.
Is there a label on your existing motor?
Take a look at this pic. They are showing Ametek Lamb numbers for the Numatics.
I suspect that you have one of these.
It should be a 2 Stage 5.7 - 240v motor.
Just look up some of these motors and see if they match up.
Ametek Lamb parts should be easy to find.
some more possibilities below, again these are probably Lamb motors with a Numatic number on them
Here is a diagram for a Numatic WV470:
http://siteassets.ransomspares.co.uk/Files/Numatic/Diagrams/EXP-0369-1.pdf
motor - 220561 230V thermal overload
Original Numatic 2 Stage 5.7 - 240v
42-VM-197
Compatible with:
Charles CVC370 Vacuum Cleaner
WV370 Commerical Wet or Dry Vacuum
WV380 Commercial Wet or Dry Vacuum
WV570 Industrial Wet or Dry Vaccum
WVD1800AP Industrial Wet Vacuum Cleaner
George GVE370 Vacuum Cleaner
CT370 Spray Extraction Cleaner
NTD2003 Vacuum Cleaner
WVD1800DH Industrial Wet Vacuum Cleaner
WV900 Industrial Wet or Dry Vacuum
Hey Adam
Go down to any friendly numatic agent repair shop and they will probably give you some from old motors they have replaced, I know I have a ton of them here but its a bit of a Far drive from the Uk to Cape Town :)
Thanks gsheen for the advice
I dont think there's any Numatic agents near me (ironic because I live in England)I was thinking about telephoning Numatic but they have way too many phone lines and they will a:charge a premium or b:try to get me to buy a new motor.The vacs are actually in the 2 year warranty boundary.their from 2015 but I dont think they were registered in the first place.All the packaging (boxes) are long gone.The place I got them from was my mums work who kill Henries very often.Thats good because I want to get one of their new model Henries or Hetties.The Numatic office is actually a few minutes away from my cousins house but I doubt they can help me.
-Adam
