Numatic Henry Question
Yes, that's exactly what it means. The wattage on a rating plate will always state the wattage at it's maximum setting. This is then broken down into two figures, one for the lowest wattage possible on the lowest permissable voltage, and one for the highest wattage possible on the highest permissable voltage. So your Turbopower on maximum setting will consume around 900w at 220V and 1000w at 240v. Rating plates don't usually indicate the different settings, but I can think of at least one which did and that was the Hoover Senior whereby two wattages were given on the rating plate, one for carpets and one for tools. Each one should be based on 240V and would use less on a lower voltage. The same can be said for cleaners which have a variable power setting which is marked by wattages on the dial or panel. These would generally be based on the cleaner being used on maximum voltage allowed.
Although I can explain the rating plates, I am no expert on how they have to be laid out and what they have to say. The fact that your Hoover Turbopower says 240V and nothing else about the voltage doesn't mean it won't work at slightly less than that voltage, as 2CV has explained.
The only difference between mine and yours is mines is 115v
There is no difference in performance between the 110v and 240v i have found
Benny - I do what ?
Mark - It says on the sticker it was made in E.C. No idea what that means though... European Country ?
Yep, I use it with pride because it was made in the UK rather than being chucked out of a factory in China or something.
I've never really considered that before. Of course being the age I am I am keen to buy British, but I've never thought about feeling proud to be using a British product. I just use them. I like your comment.
Made in the E.C. means "Made in the European Community", as in, it's parts were made in various locations within the European union, but assembled in one place... :S
The "1000W IEC" mark means it'll use about 1000 Watts "In the European Community", rather than, say, using 1000 Watts like an Interstate Engineering Company TriStar CXL, like mine, which has a chinese clone of an Ametek motor, originally for a Henry, fitted in it's belly... :P
As for the 110v/240v comparison, it's hardly surprising they work the same as they use standard Ametek-Lamb motors (or chinese clones of depending on where they source them), so they use the same designs but change the field coil to work on 110v or 240v... :)
It isn't just my Numatic I feel proud using though, it is also my 1977 HOOVER Ranger, which was made in "Great Britain" according to the ID plate (I say plate rather than sticker because it is a metal plate, ah, the good ole days!)
It is good to see that Britain can make good things, and both my Numatic and HOOVER are very good things!
Personally I take pride in using well-engineered designs, regardless of their origin, and take even more pride in fixing them up and making them work, or improving them so they work better... :)
(it amuses me though that pride is one of the seven deadly sins, cos pride just gives a warm, happy, fuzzy feeling inside!!)
2CV thank you for the comment about the IEC. As I said, I wasn't 100% sure I was right on what it stood for. So do you happen to know why they are giving more information other than the top wattage?
