Newbie help: Interstate Engineering Compact Identification
Thanks!
After your response... I found you have answered this question before.
New questions:
1. Do you have any methods for cleaning the cloth cover over the hose?
2. If you were going to paint would you use epoxy paint?
3. Is the casting aluminum?
Thanks again!
Ben
Hi Ben
The cloth covered hose can be cleaned with a cloth dipped in a solution of woolite and water, rung out almost dry.
The original paint is hammertone finish, the best way to paint would be a very light spray standing from about 12 inches away. Let the paint rain down as a light mist. This will preserve the 'wrinkles', which is the way it was originally.
The casing is aluminum on yours - later ones would use a combination of magnesium and aluminum forming a compound Interstate Engineering referred to as "magnalite".
