New Sebo Cordless Bagged Upright
Huh...
I never thought I would see a direct air machine made by them at least not in modern times. Suppose though the efficiency is better suited to battery run products.
Yes the more filters you add the more the airflow gets restricted and the harder the vacuum has to work. On a wall powered vacuum that's no problem - but on a battery powered vacuum this will kill your charge pretty fast.
Indeed, you don’t need a 12 amp motor to clean carpets well. Classic fan first Eurekas and Hoovers deep cleaned carpets very well with motors that were 4 or 5 amps only. This Sebo is designed to only clean carpets like a basic Hoover Elite, Eureka Bravo or Oreck.
