Reply to thread
Well
I'm not too terribly impressed with it. I see that it uses the same brushroll set up as the Versamatic/360 and versamatic plus/370, and i feel their dual row brush is a better cleaner. It seems to be a single motor system, if you watch this video you can see at about 4:20, after he removes the bag chamber, there are two tubes coming from the base, much like the Sensor/G/X. so unless they've used a difference motor it's performance would be like pairing a Sensor/G/x series motor with the brushroll from the 370. I know the 370 had higher airflow than the Sensor S12 i had, so i cannot see this being a better cleaner than the 2 motor systems, or the single motor machines with the dual row brushroll.
The only things i can say i like about it up front are the interchangable cords, as in commercial environments you can chew through cords pretty quick, and having the switch mounted in the base, eliminating wiring running through the bag chamber area.
[URL unfurl="true"]http://https//www.youtube.com/watch?v=VZklsjaZENY#t=304[/URL]
