hexamoron
An update, or more of cry for help from the last post; the Radiant arrived safely and had the exact malfunction that was described (the messed up auto-drop). As I planned, I took it apart for cleaning as well as to search for the source of the problem.
Everything went smoothly, it began functioning better with a few small adjustments, not quite usable yet but close. This was, of course, until I moved to reattach the shells.
Since I had someone else help with the process, I might've not stressed clearly enough how /careful/ they needed to be with the toaster. After the shells were back on and the entire unit was reassembled to the way it was before, I went to test it.
I plugged it in and was met with a completely unresponsive unit. Usually when powered, it emits a low droning sound as is expected with something of its age, but there was not a single sound. It was as if it wasn't even plugged in at all, the /actual/ test was met with identical results, it would not drop, heat, raise, anything.
Taking it back down to the garage/workshop, I took the base off and found no issues with the cord or its connection, so I'll need to throw away the several hours it took to put the shells back on and take them /off/ again.
I don't know what to do, this seems like a hopeless situation, only made worse by the sentimental attachment I have to this toaster.
I may or may not be able to send further information tomorrow.
