Hello here.
I'm a proud owner of a Kirby Sanitronic VII since a few days.
My goal is to fully polish it and use it as my regular vacuum.
I almost have old stuff
I think I need your help.
First note I'm not a newby about mechanic, it's my job.
So I also take care with old things ..
Here's the problem :
The bearing are quite noisy, so I suppose they are dead. Since the Kirby is dismantled now for polishing, I might as well changing them.
The problem is I'm not sure how to change them. I have to remove the rotor, and the turbine I suppose.
Is there anything special about this ?
I usually heat the casting and use a puller, but I prefer to take care and ask before.
I also could not find any decent schematic about the inside, this will help.
Any advice ?
Thanks a lot.
Any advice ?
Thanks a lot.
