I've been wanting to write this for a few weeks and finally had some time. I'm going to review the Ritello, the Roboclean and then give my vote on which separator water machine I would recommend to a general consumer who is not a collector, let's start with the Ritello.
I actually bought this machine used, but it was in very good shape. It's the Renaissance edition which is the newest model. I'm going to keep these reviews pretty short since there is a lot of redundancy between the water machines.
The Ritello is very similar to the Rainbow, I think Librex, the company that makes it was actually trying to clone the Rainbow, however, I think they have fallen short in a few areas. Like all of the other water filtration machines, the Ritello has the three parts, dolly, basin and motor unit. The dolly and basin are very similar to the Rainbow so I will focus on the motor unit. The one thing I will say about the basin is that it's not totally open like some of the other machines are which does make cleaning it more difficult.
The Ritello does have one very nice feature that the Rainbow does not, a cord winder. A cord winder makes storing the cord so much easier, this is definitely something that Rexair should add to their next model. One thing I definitely do not like about this machine is how the latches work. The Ritello uses two round clips that go in to the side of the motor unit. Once they are inserted, you turn them to lock the motor unit in place. I would suggest keeping the clips in your pocket when not attached to the machine, if you lose them, you will have no way to secure the machine together. I have no idea why they chose to do things that way, but I don't think it's as good as the system the other machines use. The hose inlet is in front and the exhaust cover is on the back. You can remove the exhaust cover to access the blower port. On the top of the motor unit is the control panel, there is a power button, a plus button and a minus button. The plus and minus buttons change the motor speed, the Ritello has four speeds. I am fairly sure the Ritello is using the same motor as the Sirena, the separator looks identical and the motor sounds exactly the same, the Ritello also spins a turbo brush at exactly the same speed as the Sirena when the Sirena uses the electric hose.
The hose looks very similar to the Rainbow hose, however there is no way to set the power nozzle to stay on, you must hold the triger for the power nozzle to work, the hose does not swivel.
The wands are very similar to the Rainbow's, they are not telescopic which means your reach will not be as good with the included attachments unless you use a wand other than what is included. The power nozzle the Ritello uses is the Wessel-werk ebk360 which is a very good one, it provides 5 height adjustments and is the best power nozzle that Wessel-werk makes. It also includes the other typical attachments, for hard floors it includes one of those combination attachments that let you switch between carpet and hard floors. I'm really not too fond of these and prefer a dedicated hard floor brush.
The Ritello's cleaning ability is similar to the other water filtration machines and like the Rainbow, you can store the motor unit on the dolly without the basin when not in use.
Perhaps it's just me but the quality of the Ritello does not feel as good as the other water machines, I have not had any problems with it, but it just feels like it's not made as well as the other ones. I'm glad I have one since I'm a collector, but because of the lack of quality feel and the way the latching system works, this would probably not be my first choice when it comes to a recommendation. Also, there are very few distributors that sell it, I'm in Saint Louis and the closest one to me is in Indiana..
Mike
Mike
