shrink1982
Active member
I have a Kirby Diamond Edition and this really applies to most Kirby's. While there are both pros and cons to the Kirby models, overall, it really depends on your needs.
Pros: Excellent at cleaning carpets. I don't think you can get a better vacuum for carpet care. Great suction and the roller really agitates the carpet and grooms it nicely. The build quality is excellent. Taken care of, these vacuums will last a very long time. I frequently run into Kirbys that are more than 50 years old that still work. Tech drive is nice. It basically helps push the vacuum a long as it is mostly metal and quite heavy.
Cons: Not great for bare floors. Also, in order to use attachments, the front nozzle needs to be removed and the hose attached. This is very inconvenient if you need to use the hose in a pinch. Also, because it is direct air, the suction is not very good with the hose attached. This vacuums leaks dust EVERYWHERE. Forget filtering the air. Every time I use this machine I get a headache. It is also very heavy and if you have stairs, you need to have normal upper body strength to carry this machine. Sales tactics are HORRIBLE. Not a good company.
Overall: I am switching to a Sebo D4. I want something that will work well on all my floors, filters the air, and is a quality product. I cannot fault Kirby in regards to its ability to clean, however, if you want flexibility and any type of air filtration, this vacuum does not make the cut.
Carpet Cleaning: A
Hard Floor Cleaning: C
Ease of Use: B
Attachments: B
Versatility: D
Air Filtration: D
Build Quality: A
Overall Score: C-
Carpet Cleaning: A
Ease of Use: B
Attachments: B
Versatility: D
Air Filtration: D
Build Quality: A
Overall Score: C-
