My First Electrolux!
allisonok
I've been researching Electrolux vacuums for a few weeks and yesterday I came across this model G in an antique store for $5! It's in pretty good shape and runs great. The cord rewinder doesn't work and it's missing the door for the exhaust port. I want to touch up a few paint dings and check the motor out before I use it on a regular basis. I still can't believe how cheap it was!
Congrats on the early model G. The cord winder shouldn't be hard to fix. The louvered door over the exhaust should be a blue plastic piece.
Tipping it helps a little but, it still won't take in very much of the cord. I'm glad to hear it's an easy fix. I'm going to try doing all of the work myself. The motor sounds great and seems well lubricated since it keeps spinning for a bit after it's turned off. I just want to check it out for peace of mind.
Is there any way to lubricate the front wheels? I disassembled and greased the rear wheels and the castor but can't see how to remove the two front wheels. The bearings on the castor were bone dry and didn't want to spin. The whole vacuum rolls quietly and smoothly now.
Nice Model G's
Hi allisonok:
Welcome to Vacuumland. You got a very nice model G. The Cordwinder can be fixed. I have several earlier models. As to the G, it dates back to the early 1960's. Personally, I avoid using the cordwinder due to their age. I keep mine fully coiled and use an original Electrolux cord to suply the power. The problem with the early cordwinders is that the coil spring tends to get sprung rendering the winder inoperable. And you don't want to repair that spring as it's razor sharp. As to the winder for the G, they can be easily replaced. And I agree with Andy, Nathan can do that for you.
All you need now is the correct hose and you're in business. Hoses are a dime a dozen on Ebay.
Happy New Year,
Alex Taber.
The front wheels on the Model G are non functional, the castor underneath is what the front end really rides on. Yours being one of the early model G's should have the plug for the power nozzle at the bottom of the front door. On the later model G they moved the front wheels back a little and put the plug for the power nozzle on the side underneath the vacuum just in front of the wheels.
Congratulations on becoming an Electrolux Model G owner!
Keep in mind that the spring and latching mechanism of an Electrolux USA (now Aerus) cord winder is similar to a roller shade.
When a roller shade loses its tension one needs only to extend it to the length of the window and allow it to latch, remove it from the left bracket, roll it up several inches at a time by hand; remounting it to the bracket afterward and testing it until obtaining the desired tension.
Similarly, for a cord winder, one needs to extend it several feet until it latches, remove its cover, and wind the cord several turns manually at a time in order to achieve the correct tension (just enough for the cord to gently retract the entire way). By the way, an old salesmen's tip is to dust the cord with talcum powder to help facilitate proper extension and retraction.
In either case, it is advisable to guide the object (shade or cord) with one's hand and not just allow it to retract on its own to avoid possible damage.
Best wishes. Let us know how it turns out (excuse the pun).
