Multiple topics single thread.
lesinutah
Utah
So I got my 2nd compact it looked like it was rode hard put away wet. I took it completely apart power washed everything. I thought motor was blown and there was a fire in vacuum. There is no fire the motor needs new carbon brushes but I tested coil and motor look brand new. The black stuff in motor chamber. It's spray paint.
The hose was a pos but I got a c8 compact for $40 bucks. I'm going to either put new black cord or 50 ft sentria cord.
So it's my new shioo vac.
I pulled d89 thinking wtf why have I not completed this. I took heritage axle put on the front with my wide green wheels and wide green on the back. The switch was shitty so I put a new one on. I only have to solder 3 black wires coming out only 1. I have a new safety switch I have a green led light I have never used d80 belt lifter never used with sticker on it. Polish job is 99 percent done. So tommorow my d80 and my compact should be fired up ready to go.
I have all blue trim everything with blue square emtor with brand new tradition bag and fork. Nozzle trim hood trim belt lifter power button t hood tilt switch blue wheels and blue cord led light. Here is the kicker I'm putting cr1 motor in having one speed more power and blue 13 inch nozzle. I also have bag assembly for both traditions and classic I have 3 classic motors. Blue bayou has amodel fan.
Later this week d80 brand new everything metal fan 519 coul motor housing and cr1 motor one speed with classic 3 front axle wide blues all around and hopefully this weekend heritage 2 13 inch nozzle.
I'll test and see which Kirby is King of suction wars.
I'm getting 74 janitronic I may make my own bag. Replica original. I'm going to fix up adoninize all back to green put vinyl green sticker use open source cad program and make a janitronic label. The vacuum will look original.
Did I mention all vacuums have sentria 2 custom bag assemblies.
So if you are reading think in nuts or full of it I'm posting pics maybe videos too. Give this forum some entertainment other than drama games.
I know vacuums I have done things nobody else has. I'm also making my top of the line variable speed buffer polisher sander weighs 27 lbs 7.5hp into my Kirby wanna be like Kirby factory buffer. So I can polish like Mike baldo.
So Ill stop blah blahiing but I back up what I say except Dyson imbred vacuum I pulled it out of the air. It probably could be done but I'm not dumb enough to waste my time making it im going to keep flipping and selling vacuums.
Hey
Ya I know sarcasm is a trait I also have. I'm not mocking Dyson I was mocking my joke of a thread. I read you like your Kirby c2 Adam bomb uses often. I also like the fact that your so helpful. If I need anything and I mean anything
I really appreciate
It's what makes this forum so great sarcasm and I'd say vacuum help but that's not usually the case. I do respect you do not get me wrong. Tom you know vacuums better than anyone the museum has every vacuum ever made. You know the back stories and everything. I sense the fire isn't burning about vacuums as much. Do you have to be cynical and critique people in the wrong. So respect you helped alot of people. Maybe you think we're aarogant so b s. Maybe if I changed my perception on you and you did on me we would be fine. I get you vacuumed burn out is being cynical and critique when you could be the first to post with the correct answer. You do have the answers.
What I don't get a man of your Calibre chooses critique and not help is where your efforts lie. If you didn't critique or give advice I could understand.
I'm saying your an assett you know the history. Teach people enlighten the unenlightened.
I'm not going to pretend to be a great poster. I'm good I'm bad I'm all over but the one thing I do is try to help. I also step in when bullying tactics are being played out. I argue wasting energy over s vacuum. I realize this.
Are you going to continue to be a leader ambassador to tommorows vacuum lovers. You don't even have to say it your cynical and correcting the wrong instead of promoting the Right rubs me the wrong way.
None of dysonmans vcccc crew and there is legions of you don't post. I have asked him a question I hope he will answer. I'm serious were adults no attack he called him out. Yes I have.
I hope we can get along and resolve this if not I'd only ask Dyson man if you can refrain from replying to posts I have made pointing out errors. That's all I ask. I will not bring this up again.
