Miracle mate accessories
shenny
Minnesota
My 1st post had misinformation it needs to read is Lindhaus M 30 not M 60 powerhead compatible and if not which ones are? I need all the extras only have the tank for the Miracle Mate. It’s enroute and it’s sight unseen, but need extension and hoses plus desired swivel handle. The works !
Magic mate accessories
Replying to whether the Lindhaus power head M 30 was direct connect and the seller said yes it is direct. Does anyone know if it’s compatible with the Magic Mate? Other parts still needed are hose,wand and swivel handel. Thanks
Oooh
Ah. The M30 appears to have come off an upright and wouldn't be compatible with the setup you're going towards as it should have a 35mm European connection where you'd need a 32mm or 1.25" connection. Then there's the electrical issue. The prong setup doesn't have a direct conversion to a pigtail to my knowledge.
You could replace the neck with a pigtail neck to make it work but the neck alone appears to run about $68
I'd just seek out another head one that already has a pigtail (external cord) already built onto it.
