Mid 1930s Hoover model 25 Motor Smokes
vacuumheaven05
Frederick, MD
Hi there, I recently acquired and restored for the most part, A mid 1930s Hoover model 25. It has the original wheels, bumper, and rubber handle grip which is brittle. It has a factory original bag and cord from a hoover model 28 which are both in mint condition, but it's close enough.
Unfortunately, since I tried to service the motor and lubricate it to spin freely, whenever I run the machine, the motor tends to smoke a lot, within 10 or so seconds. The thing is that, even though it seems that the vacuum runs at pretty much normal speed and the brush roll spins freely without issues, the motor still smokes. Even when I unhook the belt from the fan shaft and run the machine for more than a few moments, the motor still smokes, and I immediately notice a burning electrical smell.
It's a shame because I serviced the motor by lubricating and oiling the armature shafts and bushings in each bearing. Though the armature and fan spin freely, the motor still smokes, so I now think that somehow the windings in the armature shorted out. If that's the case, I don't know where to get a replacement armature, which has intact windings. Either I'll end up finding a spare hoover 25 motor that runs good, or I'll have to get the entire armature rewound. I don't know if someone has a spare hoover 25 motor that runs good, that can be for parts. I'm not really sure what the best thing to do is at this point?
Reply
How does one run a vacuum, such as my hoover 25 in reverse? Do you just simply plug the cord into the outlet in reverse, or the opposite way? I'm not sure
Smoking motor
I'm wondering if you might have gotten some oil on the windings, or maybe over oiled and it's getting there while running, possibly on the carbon brushes too. I would inspect the armature and wipe it down if it appears oily with alcohol or contact cleaner, making sure it's dry with no residue remaining before running it.Hopefully that's all that's making it smoke. Good luck!
I'm Wondering
I did put oil on both parts of the armature which fit through both bushings of each bearing. Is there supposed to be any oil at all in each bushing or is adding oil to the bushings the direct cause of why the motor is smoking? The thing is I do know that both bearings in my hoover 25 are ball bearings, However, they are sealed bearings, meaning they cannot be repacked with grease. Maybe because I added oil to the bushings, some of it may have gotten on the windings, which is causing the smoking. Is one supposed to add oil to the bushings in those sealed bearings, or are the bushings supposed to be completely dry? Nonetheless I will inspect the armature and try to remove and clean up all oil in the motor.
Are you removing the armature to clean the windings? If so ,there are many products you can use. I've heard people use liquid dish soap like dawn or grease removers like 409 or simple green. Contact cleaners for electronic equipment like stereos or circuit boards etc would work. You don't want to use anything that could melt the protective coating on the wiring on the armature or the field wires. It should be easy to remove any oil that got there since it would be fairly new, it's not like your trying to remove old baked on grease from an oven!
People use WD40 for a lot of things, I don't know if it works for cleaning wiring. I was told it was originally formulated for the removal of moisture in locking mechanisms. It's not the first or second thing I'd reach for. Don't forget to check your carbon brushes for any oil that may have reached them.
On bearings that were originally greased I don't try to use oil as doing so will thin out any existing grease causing a messy leak and a bearing failure.
Smoking Motor
Have you made any progress with the smoking motor? If so can you share what the problem was and what you did to correct the situation? Thanks!
The smoking is oil burning off the motor windings, which is hazardous. You have to take the motor apart completely to re-grease it, and that's with grease, NOT oil for a machine this old. And NOT WD-40 either, that is not a lubricant oil. I would never use any kind of cleaner or degreaser, not even Dawn (it has ammonia in it) on motor windings, as it will destabilize and remove the protective insulating varnish from the wires. Just an air compressor and a little nylon brush, possibly dampened with a bit of distilled water, is all you'd ever need.
Proper way to service the motor would be to disassemble the motor, degrease the non delicate parts, wipe down the armature and windings gently to get most of the residual oil off, clean the bearings and race, inspect for damage or wear, suck the old grease out of their pores (if they are porous or non porous I am not sure) then re-grease, re-pack, and reassemble and run it a lot to cook off the old oil that seeped into the windings and monitor it preferably with the hood off to make sure it doesnt start a fire.
Yes it is very involved, and sounds like a lot of work only because it's written out. Everyone just learning should always start on newer, crappier vacuums, and learn how parts go together, learn how the entire process works, and not just jump into tearing apart antique vacuums, there's a whole lot more to learn (and to go wrong). You also need a lot of tools and products to do the job properly.
Reply to huskyvacs
Yes, that is correct, from thinking about this for a while now, I believe that the reason for the motor burning is due to oil getting onto the armature and field windings or commutator where the carbon brushes are. I will do my best with removing all oil from the armature and will thoroughly clean it. I will see what I can do with re-packing the ball bearings, both the front and rear ones.
Question regarding re-packing bearings
How does one re-pack a sealed motor bearing, as most older motor bearings are sealed and cannot be easily repacked? I don't want to risk damaging the spacers and bushings. What type of tool would be best for repacking the bearings of my hoover 25 motor?
