Reply to thread
I also have a model 62. It's my favorite Hoover. It has a really great sound when it's running. I bought it 35 years ago for $2.35 at a house sale.Back then you could get all the parts you needed. But now it's a problem. The bellows you are going to have to hunt for it, also roller brushes and they are not cheap. your lucky to have found W bags for it. You might be able to switch to the later type A top fill bags if you get the complete bellows assembly from a later 1980's model hoover also you might be able to switch to a later model brush roller if your brushes are wore out.Mine is still original equipment if you want to keep it that way you have to always be looking for a opportunitiy to find parts such as always in your travels be on the look out for a old time vacuum repair shop. Not to many left but sometimes you get lucky. when I go to different citys I look in the phone book and check em out. You should grease your motor bottom bearing  and check the brushes also lube the brush roller bearings for a smooth running machine. Good Luck Bill,
