manual or automatic height adjustment for uprights and power nozzles
n0oxy
I thought this might make for some interesting discussion, when it comes to cleaning carpets, do you prefer automatic or manual height adjustment? Certainly manual adjustment gives you much more control. I've found that some automatic height heads will float in order to adjust to different carpets, but many are just set to one height, which is probably in the mid range. If you use manual height adjustment, what do you think is the best setting? I would think you would want to set it as low as you can while still easy to push. On some power nozzles such as the Sebo, there is a light that will indicate when your brush is too high, do you rely on this or use your own judgement? Again, I would think going as low as possible while still being easy to move would be a good setting. On power nozzles such as the Aerus, it's automatic, but they claim it will clean all carpets well, not sure how true that is though.
I prefer manual myself.
Most that are self adjusting do just what you said...they float across the top of the carpet because there is no weight to the power-head.
I personally like the Kirby system the best, it allows for all types of carpets. The best setting is not having it set all the way to the floor. The setting should allow the vacuum to pick the carpet up to vibrate the dirt loose. Using this procedure allows for better air flow as well.
Just my 2 cents.
J don't really have any uprights or power nozzles that auto-adjust that I can think of. I agree that manual would probably do a better job. I have two types of short pile carpeting and usually use the XLO or Low setting depending on which one I'm vacuuming.
I like the Kirby system...
Because there is no guesswork. Just lower the power nozzle until you hear the brushes make contact with the carpet, then lower one more click and you are at the correct height for your carpet. This method works for all types of carpet.
With manual height adjustment I have noticed that the pattern of the wooden floors underneath can sometimes leave their imprint on the carpet above. This is down to the force of the carpet pile being constantly cleaned with a manually "locked height" brush bar.
What most people don't realise is that a canister vac with a suction only floor nozzle does not have a locked height position. If the vacuum cleaner didn't have variable suction between the vacuum air of the floor nozzle and had wheels that roll over spongy pile, then the floor head would clamp down making it impossible to move. A bit like pressing the pedal on the floor tool to carpet position and then finding the floor head is impossible to move.
I much prefer automatic height adjustment - less wear and tear on the carpet at the end of the day.
If the auto nozzle height adjust works right-fine-If not manual adjust for me.The auto height on the Sebo and Riccar-Simplicity vacuums works pretty well-no beef with those.-Carpet airlifted by the nozzle-roller brush not too low or high-and machine easy to push.
Not necessarily so, Matt. sorry but I disagree. It depends on the pile of course but also how the carpet has been laid in the first place and if it hasn't been finished and nailed onto the sides of each part of the hall way or walk way - or wherever it has been placed - to allow "give" when the carpet is laid on the floor.
A carpet that has underlay already fitted to the underside of the carpet seems to be the issue PLUS adding the weight of a controlled height upright. I suspect that was the problem with ours - since the underlay was automatically bonded on, several rooms show signs of the imprint of floor boards coming through. Only way past it has been to steam the carpets, fit new underlay on and then roll the carpet so that it fits over the new underlay.
We were recommended NOT to use an upright on the type of wool carpet we bought. I couldn't abide the amount of dirt and hair the carpet accumulated (and when we had dogs) and so delicate brush rollers were used so that they dig deeper into the carpet but doesn't flatten it so much, or rather rip out unnecessary top pile carpet if its an aggressive brush roll. Auto height seemed to be better for the carpet generally or suction only.
The other thing of course and slightly away from topic are carpet washers - suction only or roller bar and after all, they don't require height adjustment.
I suppose if they did offer manual height adjustment, the brands could be in danger of being sued given the three processes of pumping water into a carpet, agitating the pile and then sucking the water and dirt out. Too much clamping onto a wet carpet with height adjustment might just leave a carpet threadbare! Three processes of wash cleaning versus dry dirt suction and agitation are of course not comparable given that wet carpet is more fragile than dry.
However, after seeing what my Bissell was still ripping out of my carpets seven years on, I was actually relieved when the machine broke down. If it was cheap carpet, then the carpet itself wouldn't still look as good and the pile would be ripped to shreds.
So I did not buy a cheap carpet despite the bonded on underlay.
However I doubt I will own a carpet upright washer with a roller bar again, unless of course I change to a less delicate carpet.
Manual all the way
When it comes to machines, be it vacuum cleaners or cameras or whatever, I'm a control freak. The more control I have over the machine, the better. I have a brain and I know what I want the machine to do. I don't need the machine to try to make arbitrary decisions based on lowest common denominator data. Machines like that are designed to perform acceptably under average conditions, which means that at best you get average results. The engineers who designed the machine aren't present in my particular environment and conditions. I'm the one who needs to make the final manual optimizations to the machine's settings to achieve the results I desire. And for what it's worth, I've never seen the pattern of a wood floor show up through my carpets, but that's probably because there's a concrete slab under them. If there were a wood floor there, the carpet wouldn't be.
Bonded on underlay.....
Sorry... but bonded on underlay usually means cheaper quality flooring. And I'd expect this type of carpet to show the floorboards all day long. I used to work in the flooring industry, both in sales and fitting.
A 'proper' carpet with a woven backing shouldn't be nailed down. It should be stretched onto good quality carpet gripper rods. Also avoid the rubber waffle type underlays as they flatten quickly. Foam is the way to go with underlay these days.... always use the Cloud9 stuff personally.... can't fault it.
Unless it is wool loop / berber carpet then you're fine to use an upright. In fact, uprights, or at least a machine with a decent rotating brush are best for most types of cut pile carpet as it helps groom and restore pile.
The BEST height adjustment!
Ever devised is the Hoover 150 from 1936, nothing has ever equaled it.
Manual is better
My experience is, that manual height adjustment is better.
Note, that I only have experience with Kärcher (Sebo BS36) manual, Miele SEB-217 and Lux automatic powerheads.
Smaller Miele and Lux powerheads are only suitable for low to medium pile carpets. On the higher pile carpets they "sink" in to the carpets and become very hard to push. Although they do OK job on the low pile carpets, bigger Kärcher powerhead is the most effective for sure. It also works well on all type of carpets. But in this case Miele and Lux powerheads are much smaller with small brushrolls.
