Maintenance Schedule for Rainbow E2
luxlife
Under a Pecan Tree
Can anyone tell me how often the rubber and foam seals that go between the machine and the water pan need to be replaced? Although my machine isn't very old (model w/LED lights), I've noticed a small amount of water on the outside of the pan when I go to change it. Have any of you ever replaced these seals before?
There is no set time
Hi There, I am a rainbow technician and as far as I am aware there is no set time to replace any seals on any machine. HOWEVER if I am doing a service I just replace them at the FIRST sign or wear or imperfection. THe biggest killer of bearings and other motor components in the rainbow is moisture, normally caused by being left on the bowl in the cupboard. I would take a look at goodvac site for replacements in the US and for any Australian's the link below will work for you
http://www.vacuumspot.com.au
