aeoliandave
Maybe your LX door doesn't open as wide as it used to? Maybe a wee bit sluggish? Check out the flexible tube beside the hinge fitting. I knew I'd have to do this eventually - mine snapped in half.
Electrolux engineers used clear Tygon (aka aquarium tubing), which at the time was all the Jet Age rage; they couldn't know this material hardens and breaks down into a gooey brown mass over time. Also reacts badly in contact with brass, which is what the LX nipples are. We player piano folks know Tygon and Perflex all too well.
Anyway, this 'stiff & sticky' really slows down the door action sequence. Pictures show the exactly 7" long tube I replaced with thick wall grey player piano trackerbar tubing - this has the long life & flexibility to withstand the contortions the tube goes through when the door flys open, without binding. The brass nipple connector at the suction adj. dial was clogged with green/brown gum as was the nozzle inner sensing 'rivet', which has in fact a pinhole bleed on its end.
I also inserted a ballpoint pen spring inside the nozzle end of the grey tubing where it takes that torsional 90 degree bend through the door frame to prevent collapse. The length of the tube is crucial as the tube must allow for folding when the door is closed. Too short and the tube stretches - too long and the tube pinches and kinks. 7".
Now the door flings open, the nozzle bumper bottoms out with a satisfying thunk, and the demonstration bag I concocted filled with a shaped styrofoam block flys a good 12 feet across the room. Whee! I'll be doing this retrofit on the other LX's.
Dave, a new member up here in Canada.
