Air Flow
I had this vacuum and it has way too much power with a very small relief valve. Impossible to use the sidekick on the bedspread or sofa. You also cannot vacuum your drapes, it will suck it in and wrinkle them.
Also I reported a vacuum bag problem to Aerus, it separates the inner liner from the outer bag. Aerus actually had me send them samples, which I did. They said they were having the problem corrected but it would not affect filtration. That is bull if it leaves the outer bag exposed to debree. I have been using the DVC Brand Type C bags in my other Electroluxes since then. By the way, they sent me another box of 24 bags and they had the same problem.
So I gave this vacuum to my newphew who just purchased his first home and bought the Lux Legacy. Air escapes through the handle of the vacuum. I am done with Aerus until they can correct quality control and realize they need a variable speed motor for their top of the line cleaner.
I am truly an Electrolux and Kirby fan, but this is not tollerable.
Bud
