oldskoolguy
So I took apart my sentria because I accidentally sucked something up somehow and jammed the fan Well, not completely apart. I gave up after removing the tech drive, but that’s another story. I was able to shake it loose, but it appears as though a connector came loose. I could not see another contact anywhere or another wire disconnected so I left it alone thinking it was nothing. Now as it turns out, I can’t get the light to work on the vacuum! Everything but that one wire is hooked up. It’s a pain to take it all apart since the actuator rod fell out during reassembly (also another story), so I’m wondering if there’s anyway I can to this just by popping the top off (there’s too many screws to take it all apart to just get the motor itself out, so I’m intimidated a bit). And for that matter, where does the connector go? I’m thrown off by the absence of contacts just in plain sight. I’ve included a picture for reference, but I don’t think it’ll help much, I’ll gladly take the Kirby apart a bit and retake the photo, but I’m not home right now.
