Kirby Question...
sharkcar19998
Michigan
So i am buying a Sentria II ( 2 ) after school at 3:30 today. The seller Claims it has a " Blown Motor ". Just wondering what else besides the Plug and Fan it could be. I am going to make sure i plug it in before walking out with it. And inspect the fan. Thanks for the input!
If it truly has a blown motor,
you might NOT want to plug it in. I've seen Kirby motors spark and nearly catch fire! Also, it's possible that nothing will happen if the machine won't turn on.
Bill
Bad armature.. Missing Carbons... Poor connections...
Theres so many things it could be... Could be something binding the shaft. Usually its the armature.
Could very well be the cord, I had one on a G4 that looked totally fine but the juice went in one end and didn't come out the other! I personally have never seen a Kirby with a bad motor, they are very reliable.
Test the cord with a volt-ohm meter (aka multitester). Disconnect the cord from the machine, and with the meter on the ohms setting (marked by the Greek letter Omega), put one probe into one side on the female end and touch the other to each of the male ends. The meter should react (full needle deflection on an analog meter or some sort of number on a digital one) when touching one of the male ends. If it reacts to both, you've got an internal short. Repeat the process with the probe in other female end and you should get a reaction out of the opposite side that you got before. If not, the cord is bad.
Also, you might want to--with the machine unplugged, of course--take the nozzle off of the front and try to turn the fan with your finger. This will tell you if the armature is frozen up.
As others have noted, Kirby motors are pretty robust. They don't just quit like those on cheapo plastivacs made of chineseum.
James and I were on FaceTime when he attempted to test it. It didn't turn it on.
He put a G3 powerswitch in it. It runs flawlessly now.
As for kirby's that nearly catch on fire
My mom's friend brought her diamond edition for me to look at it because it had problems
When I tested it, I realized it was a fire hazard. There was bright blue and orange light flickering out of the base of the handle and the exhaust port. It sounded terrible.
She plans on getting a brand new rainbow and giving me the diamond. I am using it for parts.
