Kirby Heritage II - Problem with flood light
kirbyrama
Pennsylvania
I had just spent six dollars for a new light bulb for my Heritage II Kirby. I replaced it because the old bulb was blinking. Now it does not work at all(after I installed the new bulb). I am quite sure it was installed correctly. What could be the problem? Is the socket mechanism worn out? After all; the vacuum was made in 1986, and that part is probably the original.
Replacement headlight parts:
108979 - headlight lens cover (models 3CB/L2)
109273 - headlight bulb (120V, single contact) (models 1CB/L2)
110878 - headlight wire w/terminal (models 3CB/L2)
111678 - headlight wire insulation tubing (models 1CB/L2)
