Kirby heritage 2 13” nozzle
Thanks guys, couldnt find those parts anywhere in stock so i was able to push out the rivets and added 8 inch zipties and it held up perfectly fine. idk how long itll last but seems pretty sturdy.
The
Bottom plate off a ds 80 should fit. If you could rivet it on it would work. You could use very small metal screws to hold the hinges on.
You could get a regular heritage nozzle for parts. Get hinges and parts off of it.
If you use a set tool you could pop out the rivets of the heritage nozzle and reattach on h2 13. You then use needle nose and flatten out the rivets.
There's a few ideas.
